Date/Time: Fri, 18 Apr 2025 16:42:28 +0000
Using ASCII text - How to?
View Count: 742
[2023-01-17 14:02:47] |
TopGunTrader - Posts: 191 |
Hi, I'm trying to paste in ASCII text to put arrows up/down to market up swing highs/lows with up/down triangle ascii and can't figure out how to do this or even if its possible. |
[2023-01-17 16:17:46] |
John - SC Support - Posts: 39356 |
You can't do this. If you want a drawing tool to make markings like this - use the Marker drawing tool. It has options for these kind of items. Refer to the following: Chart Drawing Tools: Marker For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-01-17 16:28:20] |
Fantastic! Even better!
