Date/Time: Sun, 04 Oct 2026 01:55:41 +0000
line drawing color
View Count: 3352
| [2014-06-04 13:01:43] |
| Carol Rutherford - Posts: 66 |
When I use the line drawing tool it has a default color of blue. Can I change the default color? I can change the color after I draw the line but that is cumbersome. I've read a lot of the material on changing the colors and so on but couldn't find a way to change the default color setting. Thanks, Carol |
| [2014-06-05 10:37:26] |
You need to change the color through the Line Tool Configuration. Refer to the documentation here: http://www.sierrachart.com/index.php?l=doc/doc_Tools.html#DrawingToolConfiguration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
