Date/Time: Fri, 18 Apr 2025 16:35:18 +0000
Numbers Bar Data Not Showing
View Count: 488
[2023-01-17 12:20:44] |
User791987 - Posts: 2 |
Since the update on 12th January 2023 the data on Numbers Bar isn't showing! The trend is there but not the actual hard numbers.... I have the Advanced service package and the chart was working previously. https://www.sierrachart.com/image.php?Image=1673603433204.png |
[2023-01-17 12:48:03] |
User431178 - Posts: 648 |
What happens if you increase the bar spacing? Working With Charts: Changing Bar Spacing Yours is set at 12 (green number bottom right hand side), so maybe the numbers are being cut off, try 60 insstead. |
[2023-01-17 15:52:30] |
John - SC Support - Posts: 39356 |
Please get us a copy of that chart by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
