Date/Time: Fri, 18 Apr 2025 16:37:32 +0000
In replay mode, the daily chart doesn't replay with the rest of the charts
View Count: 357
[2023-01-16 23:33:20] |
User897692 - Posts: 9 |
The daily has the same link number as the lower time frame charts but it won't replay when I click "Play"
[2023-01-17 15:23:35] |
John - SC Support - Posts: 39356 |
Replay only works with Intraday charts. It does not work with Daily Historical data. Refer to the information here: Replaying Charts: Introduction For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
