Date/Time: Tue, 22 Apr 2025 02:27:41 +0000
Suggestion: Progressive fading of DOM recent trades
View Count: 629
[2023-01-16 19:09:53] |
BenjFlame - Posts: 337 |
Hi, older recent bid/ask trades on dom are polluting the columns after a while. An easy way to remove the need for frenetic clearing of the columns would be a new setting, in milliseconds, for fading the recent bid/ask numbers. For example: if I set it to 10000 ms.... as soon as the price level is leaving a cell, the number inside will take 10 seconds to completely disappear, progressively. If the cell is hit again before 10s it will reset the fading counter and visual. That would be an excellent way to see the most recent trades without having to clear the bid/ask columns constantly. Also no other software implements this (it would be better than trail of intention) and would give SC dom an edge. Of course, a setting of "0" would keep the current behavior with no fading out. |
[2023-11-29 14:04:17] |
User293778 - Posts: 21 |
+1
[2024-11-20 00:25:07] |
User326898 - Posts: 1 |
+1
[2024-11-20 11:46:54] |
Sébastien - Posts: 58 |
+1 This would help a lot. |
