Date/Time: Tue, 26 Nov 2024 17:17:46 +0000
Erasing all drawings
View Count: 2910
[2014-06-04 06:45:43] |
Dom7364 - Posts: 257 |
What is the way to erase ALL drawing, i.e, lines, circles, rectangles, exetended rectangles etc? I do "erase all lines" but it doesn't erase extended rectangles for example.. |
[2014-06-04 07:28:41] |
Tools >> Erase All Lines will erase extending rectangles. If it does not, it means they are locked. Check the status of them in Tools >> Manage Chart Drawings Window. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
