Date/Time: Mon, 28 Sep 2026 12:19:48 +0000
Chart will not load more days
View Count: 3147
[2023-01-15 14:56:53]
58LesPaul - Posts: 429
I have changed the days to download on my 120 minute QQQ chart to 50 days and it still only loads back to 12-27-2022. Which is what the date range in file shows but I have "Load Data Limiting Method" set to "Use Number of Days to Load" and have "Days To Load For Intraday Chart Data Type" set to 50. If I try to change the "Date Range in File From" to go further back it just changes back to 12-27-2022. How can I get more days to load on my 120 minute chart?
Date Time Of Last Edit: 2023-01-15 14:58:31
[2023-01-15 16:07:05]
Sierra_Chart Engineering - Posts: 24994
There is no chart setting to do this:
You need to go through the instructions here:
Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data
[2023-01-16 00:55:35]
That is exactly what you linked states;
To load more data in the chart continue to follow the instructions below.
Select Chart >> Chart Settings >> Data Limiting on the menu. .
Set the Load Data Limiting Method setting to Number of Days to Load.
Set the Days to Load for Intraday Chart Data Type setting to the number of days you want to load and view in the chart. Press OK.
Anyway, I deleted all data and downloaded again and it worked.
[2023-01-16 04:16:55]
Yes the additional step is performing a delete of the data and re-downloading.
[2023-06-12 20:30:26]
PermaBull - Posts: 10
Hi there,
I just bought package to have full access to Nasdaq stocks and I am unable to download history.
I have already tried following,
1) install new version of Sierra chart
2) change the chart setting to go back 400 days
3) delete and re-download data.
yet I am unable to get historical data. can you help.
[2024-10-16 07:05:23]
User745789 - Posts: 398
I followed these instructions and for Denali EUREX I am not able to get historical continuous data from before Feb 2024 for a 15 min chart
[2024-10-16 15:03:55]
John - SC Support - Posts: 48028
Did you also setup the chart to be a "Continuous Futures Contract"? Refer to the following:
Continuous Futures Contract Charts
[2024-10-16 23:35:58]
Yes, I am using continuous contracts.
I note that with two seperate SC folders, one using Denali EUREX, one using CQG OSE: both exhibit the same issue. Very limited history for 15m continuous futures charts.
[2024-10-17 13:35:09]
You will have limited data from CQG. They do not have data for previous contracts. Therefore, if you have not already downloaded the data for previous contracts, you will not want to use a Continuous Contract.
You should not have any issue with getting the additional data for EUREX from our Denali Exchange Data Feed. What is the symbol for the chart?
[2024-11-28 08:49:14]
User555708 - Posts: 16
same issue for me. I have always been able to go back as far as a want on all charts, yet today I cannot go back over 1 year.
Please advise
[2024-11-28 22:22:49]
For what symbol are you having this issue?
Also refer to:
