Date/Time: Fri, 18 Apr 2025 04:01:27 +0000
questions about heartbeat logs
View Count: 386
[2023-01-15 12:07:26] |
d9e5c763 - Posts: 111 |
1 "TETON CME Order Routing" will appear in the sub-instance and the main-instance, does this mean that the order does not need to be sent through the main-instance? 2 what is the difference between "SC DTC DATA with Market DEPTH" and "Sc Data -All Services" ? I see these two info at the same instance. |
[2023-01-15 16:08:16] |
Sierra_Chart Engineering - Posts: 19257 |
1. Orders from a sub instance always go through the main instance. 2. These are different servers for different categories of data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
