Date/Time: Fri, 18 Apr 2025 16:39:58 +0000
Analysis menu not showing all my study collections in data folder
View Count: 478
[2023-01-14 11:12:19] |
User61168 - Posts: 433 |
Hi SC Support, I have 100+ study collections in my data folder and Analysis menu takes up the entire screen with no way to see all my collections. Could you please add a "Open Study Collection" menu under Analysis menu bar to open and apply collection to the chart? |
[2023-01-16 14:56:51] |
John - SC Support - Posts: 39356 |
Hopefully the following setting will help alleviate your issue: General Settings Window: Maximum Items per Column for Study Collections Menu (Global Settings >> General Settings >> GUI >> Application GUI) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-01-17 04:39:50] |
Thanks John. Mine was already set to 30 so increasing to 40 across 4 columns is the max limit. It would be better to add a "open study collection" from hard drive similar to Analysis>"new/open custom studies file". This way, I can temporarily "view" what is in a study collection without actually applying the collection to a chart. Good feature to add to your bucket list :-
[2023-01-17 20:47:04] |
Sierra_Chart Engineering - Posts: 19269 |
We will look into this feature.
