Date/Time: Thu, 28 Nov 2024 18:37:12 +0000
trading dom in replay mode issues
View Count: 988
[2023-01-14 09:56:52]
akx814 - Posts: 3
hi i am trying to replay with my candlestick chart and 'trading dom window' or 'trading dom for chart'.
the 'trading dom window' is synced with the chart replay but only shows the bids and asks as 1 thing.
the 'trading dom for chart' is not synced.
to sync the 'trading dom for chart' i have to separately run a replay different from the candlestick chart replay.
is there a way to sync the 'trading dom for chart' with my candle stick replay and just click it once? or is there a way to physically integrade the 'trading dom for chart' into my candle stick chart window? i dont want to have two floating windows
imagetrading dom for chart.PNG / V - Attached On 2023-01-14 09:56:06 UTC - Size: 254.67 KB - 138 views
[2023-01-16 14:54:36]
John - SC Support - Posts: 36350
Refer to the following for how to replay a Trading DOM:
Replaying Charts: Replaying Trade DOM Windows
And refer to the section just below the above for information on replaying Market Depth data.
[2023-04-13 10:06:51]
Trader685 - Posts: 1
Hi I am having the same problem as this user - I cannot find a way to replay the candle chart AND the chart DOM at the SAME TIME. I went thru the instructions to download mkt depth data and that is working fine. I have linked the charts and yet they will still not replay together. I have to start both replays separately and obviously that is not ideal and you cant stop and rewind easily and keep the charts in sync. If you can pls guide. Thanks
imageCandle Chart and Chart DOM.jpg / V - Attached On 2023-04-13 10:05:57 UTC - Size: 648.15 KB - 133 views
[2023-04-13 10:12:57]
Sierra_Chart Engineering - Posts: 17204
Go through the instructions here step-by-step carefully:
