Date/Time: Fri, 18 Apr 2025 04:01:27 +0000
In replay mode not all prices have the same value in different charts
View Count: 468
[2023-01-14 07:22:30] |
sabbers - Posts: 27 |
In attached example i have four charts for ESH23-CME E-mini S&P500: - marketprofile - vwap - dom - footprint prizes on dom and footprint charts are not the same as on marketprofile en vwap chart. How to fix this? Thx! |
Private File |
[2023-01-15 15:49:14] |
Sierra_Chart Engineering - Posts: 19257 |
The problem is the charts are at different points of time. They are not synchronized. To keep the the charts being replayed synchronized, refer to: Replaying Charts: Preventing Loss of Synchronization Between Different Charts During Replay Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-01-15 15:49:37
