Date/Time: Tue, 26 Nov 2024 17:32:35 +0000
ES NQ DELAY
View Count: 1190
[2014-06-03 16:37:19]
User94567 - Posts: 1
Hello
Can I get delay ES NQ or any other futures without additional payment ?
Regards,
EML
[2014-06-03 16:41:05]
Yes you can through one of the supported Futures trading services:
http://www.sierrachart.com/index.php?l=doc/data.php
[2014-06-03 17:24:58]
User91402 - Posts: 6
How to change the package in the middle of the month so I will have the historical data as well?
[2014-06-03 17:30:00]
Follow these instructions:
To change your Sierra Chart service package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on "Change Service Package".
The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price.
There is no charge for changing your Sierra Chart service package. Only your usage time is adjusted.
