Date/Time: Fri, 18 Apr 2025 04:01:28 +0000
Copy specific chart drawings to another chart
View Count: 1027
[2023-01-12 23:14:47]
User629461 - Posts: 186
I know the option exists to copy chart drawings from one chart to another, however this copies ALL chart drawings.
Is there a way to select only specific chart drawings to copy? For example, if I have a 60m, 15m and 5m chart open, I'd like to draw & annottate daily and overnight high/low levels on the 5m chart and then copy them to the 15m & 60m charts. But I dont want the other elements which dont relate to other charts to be copied (eg a 5m trend channel isnt relevant on a 15m or 60m chart).
Hope this makes sense.
Thanks.
[2023-01-13 15:19:32]
John - SC Support - Posts: 39353
Each drawing has a setting called "Allow Copy to Other Charts". By default this is enabled. Therefore, you would need to disable it for the drawings you do not want to copy.
Refer to the following for how to use this feature:
Copying Chart Drawings from Other Charts Automatically: Preventing Specific Chart Drawings from Being Copied
[2023-01-15 22:43:29]
Is there an option to disable the default to copy every drawing?
In that way I can select which drawings I do want to copy, as there much fewer of these.
[2023-01-16 04:31:12]
Sierra_Chart Engineering - Posts: 19257
There is not a way to control the default.
