Date/Time: Tue, 26 Nov 2024 17:28:17 +0000
10 day Volume By Price only showing 5 days?
View Count: 1340
[2014-06-03 15:46:00] |
harami - Posts: 5 |
I created a chart with a 10 day volume by price study which originally worked okay, but is now only showing about 5 days worth of data. I'm using IQfeed. Do you see anything wrong with these settings? |
settings.jpg / V - Attached On 2014-06-03 15:45:06 UTC - Size: 90.01 KB - 399 views |
[2014-06-03 16:30:37] |
For the Volume by Price study: Set the Maximum Volume Bar Width Type study input to Period Length. Set the Maximum Volume Bar Width Percentage study input to 100. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-06-03 16:31:40
[2014-06-03 16:49:22] |
harami - Posts: 5 |
All that does is stretch the existing data across the whole width of my chart, which makes it unreadable. The volume profile data from 5-10 days ago still doesn't show up.
[2014-06-03 17:05:26] |
With your settings, the Volume Profile will be for the last 10 days. Why do you think it does not cover 10 days? Also the chart image you posted is very unclear for us and hardly useful. You must post the image by following these instructions: https://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-06-03 17:05:49
[2014-06-03 17:14:13] |
harami - Posts: 5 |
The chart is a zoomed out view showing the last 10 days worth of 5 minute price data. The volume profile on the right side of the chart is not showing a profile of volume traded at levels during the 1st 5 days of the chart (designated by yellow bracket).
[2014-06-04 07:29:44] |
Provide an image of the chart, by following these instructions: https://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-06-04 13:26:30] |
harami - Posts: 5 |
http://www.sierrachart.com/image.php?l=1401888075740.png |
[2014-06-04 17:21:27] |
This is correct. The 10 days back will be calendar days from the last Date in the chart.
