Date/Time: Tue, 22 Apr 2025 10:23:22 +0000
Realtime data for CME- EMINI NASDAQ
View Count: 531
[2023-01-11 18:13:40] |
User538264 - Posts: 26 |
Hi, I am getting the delayed data for CME EMINI NASDAQ and other symbols. How do I get the live data for the same? Thanks. |
[2023-01-11 18:18:29] |
We see that you are setup for Netting for the NYMEX exchange. Are you already paying the CME Group directly for data for the CME exchange such that we can setup Netting for the CME exchange as well? Otherwise, you would need to activate the appropriate exchanges as a Professional. You can do this at the following link: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-01-11 18:29:09] |
Yes, I am already paying for the CME exchange already and I have the live data feed connected to TT platform. How can I get that to Sierra? |
[2023-01-11 18:56:30] |
SC Support - Posts: 1955 |
This is done The 'CME, For professionals - Netting' exchange has been internally activated, and will be renewed. This change will go in effect in approximately 3 minutes. If it does not, then restart Sierra Chart after that time. |
[2023-03-06 14:51:31] |
Hi, I think this has been deactivated again. My data feed is delayed again. Please re-activate it.
[2023-03-06 15:08:10] |
Account Name: lovekesh.azad The 'CME, For professionals - Netting' exchange has been internally activated, and will be renewed. This change will go in effect in approximately 3 minutes. If it does not, then restart Sierra Chart after that time. The 'CBOT, For professionals - Netting' exchange has been internally activated, and will be renewed. This change will go in effect in approximately 3 minutes. If it does not, then restart Sierra Chart after that time. The 'COMEX, For professionals - Netting' exchange has been internally activated, and will be renewed. This change will go in effect in approximately 3 minutes. If it does not, then restart Sierra Chart after that time. The 'NYMEX, For professionals - Netting' exchange has been internally activated, and will be renewed. This change will go in effect in approximately 3 minutes. If it does not, then restart Sierra Chart after that time. |
