Date/Time: Fri, 11 Apr 2025 21:05:00 +0000
Dom Setting
View Count: 356
[2023-01-10 18:01:03]
colonwing1888 - Posts: 26
Enclosed please find a photo.
The left number bar photo show the price from 3907 to 3925. However the Dom Chart show the price only from 3911 to 3925.
1. How can I adjust the Dom's price scale to show wider price range.
2. Please advise how to open a chart dom . If a chart dom can merge into the number bar chart ? How to do ?
imageimage.png / V - Attached On 2023-01-10 18:00:12 UTC - Size: 566.75 KB - 93 views
[2023-01-10 18:21:49]
John - SC Support - Posts: 39274
Refer to the following:
Numbers Bars: Scaling a Numbers Bars Chart
If you are wanting to trade from the chart, then select Trade >> Chart Trade Mode On. This will enable the DOM for the chart as well. Refer to the following:
https://www.sierrachart.com/index.php?page=doc/ChartTrading.html#HowtoPlaceAnOrderFromtheChart
If you just want the DOM, then select Trade >> Show Market Data Columns.
Trade Menu: Show Market Data Columns (Trade menu)
To customize the columns in the DOM, select Trade >> Customize Chart/Trade DOM Columns. Refer to the following:
Global Trade Settings Windows: Customize Chart/Trade DOM Columns (Chart Specific)
