Date/Time: Wed, 23 Sep 2026 23:38:01 +0000
A bar's end time rather than start time.
View Count: 1659
| [2014-06-03 08:20:41] |
| User26994 - Posts: 32 |
Can I change the time attributed to a bar ? eg ....I have a ten minute bar that shows as 9.00am. That time (9.00) is at the time that bar started from. Can I change it so that the time attributed to the bar is 9.10 ? ie the time when that bar will end. Thanks. |
| [2014-06-03 08:40:05] |
No. This is not changeable.
| [2014-06-03 08:44:36] |
Thanks. Is it an option that will ever be considered.
| [2014-06-04 07:34:59] |
There are no plans for this.
