Date/Time: Fri, 11 Apr 2025 12:57:01 +0000
[User Discussion] - Number of Trades Bar
View Count: 536
[2023-01-09 20:03:31] |
User578003 - Posts: 17 |
Hello, I tried to find out why my # trades bar do not match on candle and foot print candle. Check times, symbols, market times, new bar at start are all the same, but charts different, right from get go. I use 00:00:00 and 23:59:59 new york time and start bar is slightly off and gets worse. Any ideas to look for?
Attachment Deleted. ![]() |
[2023-01-09 22:30:26] |
John - SC Support - Posts: 39274 |
There is something between the charts that is different. Time Zone, New Bar at Session Start, Combine Trades into Original Summary Trade, etc. A quick way to resolve the issue is to duplicate one of the charts and adjust it to be the other chart type. This way your settings are all the same between the charts. Refer to the following for more information: Number Of Trades, Volume or Range Bar Charts Do Not Match Setting or Are Not Accurate or Are Inconsistent: General Information and Related Settings For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
