Date/Time: Fri, 11 Apr 2025 12:54:11 +0000
Pulling Stacking question
View Count: 346
[2023-01-09 16:49:07]
Rickty - Posts: 35
Sierra Charts Support,
Please confirm : if on a bar the value of pulling is -20 and on the next bar it is -80, that is a measure for each bar, not a change between bars? The difference between them would be +60, but each bar has the value (in this example) of -20 then -80? Stacking works the same way?
Just making sure I understand clearly. Thanks in advance.
[2023-01-09 21:20:04]
John - SC Support - Posts: 39274
If you are referring to the Sum Ask/Bid Pulling/Stacking from the Numbers Bars Calculated Values (as this is the only place to get a per bar pulling/stacking value) then that is the sum of the pulling/stacking numbers from the DOM for the Bid or Ask. When a bar closes, it is the value at the close of the sum of the pulling/stacking.
Therefore, if you see -20 at one bar and -80 at the next then it means that there was a net change of a quantity of -60 between those two bars. But again, it is just the value at the close of the bar (the actual maximum excursion in one direction could be larger).
