Date/Time: Fri, 11 Apr 2025 13:03:05 +0000
How to create padding between candlesticks and right side margin
View Count: 383
[2023-01-09 16:34:17]
Jimmy K - Posts: 10
How to create padding between the current candlesticks and right side Y margin. I would like to see my candlesticks to the left of the right side margin instead of right up against it.. how do I do this??
[2023-01-09 16:40:32]
DKtrades - Posts: 39
You can "Unlock" the fill space -- then make the space bigger, and then "lock" it again -- under the Chart menu (Chart > Lock Fill Space) turn off this item if it is checked, then make the changes on the chart, then turn it back on.
[2023-01-09 21:10:42]
John - SC Support - Posts: 39274
Refer to the following documentation:
Working With Charts: Right Side Fill Space
