Date/Time: Wed, 02 Apr 2025 20:29:45 +0000
Volume Profile - LVN When Off Chart
View Count: 484
[2023-01-09 15:26:13] |
User753526 - Posts: 55 |
Hi, I am using the Volume Profile on my chart for a given period (for eg. the first 25% of the screen, 15th Dec til 21st Dec) and using the LVN's further to the RHS/Todays date. However, when I zoom in further and that first Volume Profile goes far enough off screen. The LVN's no longer display even though the Volume Profile is still current on the chart. Is there a setting that I can use to ensure the LVN's and other associated levels from a Volume Profile remain present regardless if that Volume Profiles date/time range is in view or not? This image shows the first/LHS Volume Profile with the pink/purple LVN lines. https://www.sierrachart.com/image.php?Image=1673067392441.png This image is the same chart but zoomed in on the most recent chart data area where that first Volume Profile is off screen. You can see for eg. the LVN levels of 3920 3898 etc. are no longer visible. https://www.sierrachart.com/image.php?Image=1673067524817.png |
[2023-01-09 18:34:30] |
John - SC Support - Posts: 39115 |
There is not a way to do this. Once a profile is out of view, all of the information for that profile is also not displayed.
