Date/Time: Fri, 11 Apr 2025 13:03:05 +0000
no Datafeed
View Count: 297
[2023-01-09 15:25:20] |
User224179 - Posts: 2 |
Hello, I can not open my Trading Dome,I don't have a data feed and nothing is moving.... Could you help me? With best regards |
[2023-01-09 15:59:14] |
Sierra_Chart Engineering - Posts: 19129 |
Activate the exchanges that you need here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
