Date/Time: Fri, 11 Apr 2025 21:24:14 +0000
[User Discussion] - Can't display the values of the crossbar on the top data line
View Count: 400
[2023-01-09 15:20:29] |
User293951 - Posts: 16 |
Dear Sirs, I have searched for hours to find some information regarding my problem. I have given up. I need to be able to move the crosshair around each chart and be able to view the values of each bar/candle on the top most region data line. This is the simplest brief view that almost all programs display by default. Unfortunately I have not succeeded yet. I want to be able to move the crosshair around the window and to view each candle's Open High Low and Close values at the top of the chart, exactly as you see in the attached image. I have done my best but have not succeeded yet. Please show me the way to do so. Thank you in advance. https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=74599 |
[2023-01-09 15:58:41] |
Could someone please explain me how to resolve this strange issue? Many thanks in advance. |
[2023-01-09 18:55:35] |
John - SC Support - Posts: 39274 |
Sierra Chart does not display the per bar information in the Chart Header like that. You would want to use the Compact Tool Values Window for what you want. Refer to the following: Chart Drawing Tools: Compact Tool Values Window For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-01-10 00:08:46] |
I know that I can use the compact tool values window. But I would like to have the values displayed on each chart just for convenience. Does there exist any study through which I could display the values? Thanks. |
[2023-01-10 15:09:12] |
Not any built-in Sierra Chart studies. But there may be something out there that someone has developed.
