Date/Time: Fri, 11 Apr 2025 12:39:32 +0000
Cumulative Delta Volume Over Set Number of Bars
View Count: 605
[2023-01-09 14:47:09]
bap0022587 - Posts: 1
Is there a study or a way to adjust the Cumulative Delta Volume Bars study to calculate the cumulative delta volume over a set number of bars? Looking to have a rolling 9 bar cumulative delta volume as a study in region 2 to identify delta divergences on a tick chart. Thanks.
[2023-01-09 18:12:45]
John - SC Support - Posts: 39274
There is not a way to do this in order to get the full Bar information.
But, if you just want the Cumulative Sum of Study for the most current 9 bars, then you would need to use the Numbers Bars Calculated Values Study in combination with the Spreadsheet Study, or Spreadsheet Formula study (whichever you are more comfortable with).
You then use the information for the Delta in the Numbers Bars Calculated Values study and sum up the 9 bars in either the Spreadsheet Study or the Spreadsheet Formula (note that the syntax for each is different).
Refer to the information at the following links for these studies:
Numbers Bars: Displaying Numeric Information Below Numbers Bars
Using the Spreadsheet Study
Spreadsheet Formula
