Date/Time: Fri, 11 Apr 2025 12:59:24 +0000
TPO chart?
View Count: 299
[2023-01-09 12:50:10] |
User513352 - Posts: 5 |
Hi , is there a way i can test TPO chart before subscribing again to a package ? it tells me i can't load the studies that i need to subscribe. I just want to test the platform for a few weeks before making my choice? Thanks you
[2023-01-09 17:26:04] |
John - SC Support - Posts: 39274 |
We have set your account to have an Evaluation of Package 12 for 30 days. This is different from the trial, as you need to have an active package in order to use this evaluation (you currently have Package 10 active). This will give you all the features of the software for the next 30 days. If you want to keep the TPOs only, then you will want to change to Package 11. If you also want the MBO (Market by Order) information, then that would require a change to Package 12. Refer to the information on the packages at the following link: Description of Service Packages and Pricing: Integrated Packages For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
