Date/Time: Mon, 14 Apr 2025 19:10:19 +0000
Apply to Linked Charts action does not apply Studies
View Count: 443
[2023-01-09 08:01:53] |
donnicky - Posts: 33 |
Hello! I have some graph with the following linking setup as on the attached screenshot. When I add new chart, select the same linking as existing chart and click "Apply to Linked Charts" on existing chart I see that studies from existing chart do now appear on the new chart in spite of the same linking setup is applied. |
[2023-01-09 16:57:18] |
John - SC Support - Posts: 39274 |
The button for Apply to Linked Charts only applies when a chart is set to Master Mode. Refer to the following for this: Chart Settings: Chart Linking >> Master Mode (Chart >> Chart Settings >> Linking menu) With regards to the Studies, the studies will not show up immediately on the chart that has been added to the link setup. You need to modify a study or add/remove a study for the studies to then show up in the chart. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-01-10 06:07:23] |
> You need to modify a study or add/remove a study for the studies to then show up in the chart. This is exactly what I have to do. Would it be logical if "Apply to Lined Charts" did it at once? |
