Date/Time: Tue, 18 Feb 2025 23:01:50 +0000
Turn off auto-populate spreadsheet column
View Count: 321
[2023-01-08 22:13:31]
MZTECH - Posts: 29
In a spreadsheet study: When I am working in a spreadsheet I do not want the column to auto-populate the formula throughout the column when I enter a formula into a cell. I searched and could not find the answer in instructions. Thank you in advance.
[2023-01-09 16:34:24]
John - SC Support - Posts: 38034
With the Spreadsheet Studies this is automatic and can not be turned off. If you just need a cell for some reason, then you would want to use one of the cells to right of the defined "Formula Columns". The Input for Number of Formula Columns defines how many columns are the formula columns. You can also use the Input for Blank Columns Before First Study to push the studies further to the right to give you more columns that are not formula columns (if you need them).
Refer to the information for the above Inputs at the following link:
Spreadsheet Study Inputs: Spreadsheet Study Inputs
[2023-01-09 16:42:24]
MZTECH - Posts: 29
Thank you!!!
