Date/Time: Tue, 26 Nov 2024 15:21:07 +0000
How to group drawings into one group
View Count: 486
[2023-01-08 21:56:36]
Mustang77 - Posts: 122
Hi
let's say i have a few horizontal lines on myu chart, each one representing a data.
if i want to hide one of the lines, i can right click on the line then click on Hide drawing.
What if i want to hide all of them? how can i do that? directly from the chart and/or from the "manage drawing tab".
Also, is there a way to group the lines into one group which i can then hide/unhide? by simply hiding/unhiding the group of drawings so i dont have to hide/unhide one by one.
Also, regarding the software updates, lets say i have the version 2459, how do i know if there is a newer version to this without blindly updating the software?
Thank you
[2023-01-08 22:51:08]
Sierra_Chart Engineering - Posts: 17181
You cannot group Chart Drawings but it is possible to select multiple Chart Drawings in the Manage Chart Drawings Window and then hide them all at once:
Chart Drawing Tools: Manage Chart Drawings
You just need to look at the homepage of this website.
[2023-11-17 09:34:04]
User435580 - Posts: 3
Is there a Possibility in the Future to add a Feature in the Chart Drawings Window to move the Drawings up and down?
So that i can ¨group¨ and organize the Drawings. Sometimes it's very confusing, especially when you add new Drawings same named as older ones you wanna keep. Then Levels with the same Name are unsorted everywhere in the List between others.
Thank you
