Date/Time: Fri, 11 Apr 2025 12:42:32 +0000
Reorder Chart Region (somehow move "Main Price Graph" lower on chart)?
View Count: 355
[2023-01-08 15:30:03] |
peaceland - Posts: 95 |
Hi, I have searched extensively for some way to move "Main Price Graph" to another region other than "1". I would like to move price to the BOTTOM of the screen/chart, but I am unable to reorder the Chart Regions up or down, above or below the "Main Price Graph". "Main Price Graph" appears to be locked to Region 1, and Region 1 appears to be locked to the top of the chart as far as I can tell. With TradingView, I can put any pane in any order. Thus far, I see no way of doing that here. Please explain how to move "Main Price Graph" to a different region, or how to reorder regions and put Region 2 above Region 1 on the chart. Thank you, and Happy New Year! Peace |
[2023-01-08 22:46:36] |
Sierra_Chart Engineering - Posts: 19129 |
Thank you and happy new year. The setting you are looking for is this particular setting found in Chart Settings: Chart Settings: Chart Region (List) (Chart >> Chart Settings >> Regions >> Chart Region menu) Let us know if you need more help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
