Date/Time: Fri, 11 Apr 2025 12:36:00 +0000
Chart value window data is frozen and not working
View Count: 340
[2023-01-07 20:57:52]
User454729 - Posts: 21
Hi all, my chart value window was working just 2 days ago, but now the values are just frozen to the close bar of Friday. Does this work when markets are close? Or is there a setting to make it work on the weekends? Thank you.
[2023-01-09 16:13:17]
John - SC Support - Posts: 39274
The "Chart Values Window" will only show you the most recent bar's information. If you want to see information for other bars as you move the crosshairs, then you need to open the Tool Values Window. These are two different items.
