Date/Time: Fri, 18 Apr 2025 16:27:46 +0000
VbP - Volume at High and Low
View Count: 405
[2023-01-06 15:52:13]
Sudhirc - Posts: 56
In VbP (Volume profile study) under In:46 we have an option to select "Volume at High/Low". Then it will print the volume at the very high and low on the volume profile.
My request is, if you select this option:
if possible can you add another line item below that to select the top "X" (1,2/3,4,5) price levels so that i can clearly see the taper in numbers rather than just the number at the high/low.
Thank you,
SC.
https://www.sierrachart.com/image.php?Image=1673020286155.png
Date Time Of Last Edit: 2023-01-19 14:26:38
[2023-01-19 14:26:19]
Sudhirc - Posts: 56
Can you please comment on this. Thank you.
[2023-01-19 16:12:11]
John - SC Support - Posts: 39356
This is a Feature Request. We take in all requests, but we do not always comment on them.
We can not say when, or if, we will ever get to any particular request.
