Date/Time: Wed, 09 Apr 2025 23:47:25 +0000
Subgraphs with DRAWSTYLE_CUSTOM_VALUE_AT_Y not displayed properly
View Count: 506
[2023-01-06 15:34:25]
User470516 - Posts: 78
Dear SC Team,
I have subgraphs with DRAWSTYLE_BAR that are displayed in a region != 0 and on top of them there are other subraphs with DRAWSTYLE_CUSTOM_VALUE_AT_Y. Data information (contained in CUSTOM_VALUE_AT_Y subgraphs) that are located on top of the longest bars (DRAWSTYLE_BAR) of the chart region exceed the top boundaries of the region and are not visible. I have played with scale options but can't fix the problem.
Would you have any solution or ideas?
Thanks,
Regards.
[2023-01-06 18:10:01]
John - SC Support - Posts: 39249
First make sure you understand the DRAWSTYLE_CUSTOM_VALUE_AT_Y draw style:
Chart Studies: Custom Value At Y (ACSIL: DRAWSTYLE_CUSTOM_VALUE_AT_Y)
And then you just need to expand the Scale Range to see the values:
Chart Scale and Scale Adjusting: Interactive Scale Range - Expand/Compress Scale
You may want to use a User Defined Scale:
Chart Scale and Scale Adjusting: User Defined (Scale Range)
