Date/Time: Wed, 09 Apr 2025 23:10:43 +0000
formule divergence
View Count: 511
[2023-01-06 13:02:05]
User220939 - Posts: 36
Bonjour,
j'utilise le footprint en tick reversal, et je voudrais faire apparaitre une divergence baissière quand la barre fait un plus haut que la précédente mais que le volume est plus faible, et inversement.
j'ai mis une formule dans la partie "alert" de "color bar based on alert condition", mais je ne dois pas faire comme il faut, elle ne marche pas toujours
Voila la formule que j'ai mis: =if(and(H>H[-1],ID1.SG1<>0,ID1.SG1=(H-ticksize)),1,0)
merci
[2023-01-06 17:13:01]
John - SC Support - Posts: 39249
From Google Translate:
I use the footprint in tick reversal, and I would like to show a bearish divergence when the bar is higher than the previous one but the volume is lower, and vice versa.
I put a formula in the "alert" part of "color bar based on alert condition", but I don't have to do it right, it doesn't always work
Here is the formula I put: =if(and(H>H[-1],ID1.SG1<>0,ID1.SG1=(H-ticksize)),1,0)
What study is ID1?
Also, since this is going into an Alert, you do not need the IF statement. The Alerts are always evaluated as True/False statements where 0 is false and any other value is true. So you could simplify it a bit by removing the IF portion and just having the following:
=and(H>H[-1],ID1.SG1<>0,ID1.SG1=(H-ticksize))
