Date/Time: Tue, 08 Apr 2025 15:47:03 +0000
cant log on
View Count: 314
[2023-01-05 15:27:56] |
User298588 - Posts: 19 |
hi i already made fulll payment, somehow i cant get connected, please take a look at it thanl you |
[2023-01-05 15:31:26] |
John - SC Support - Posts: 39213 |
We need more information on exactly the problem you are having. Everything about your account looks good. You are able to log in to this Support Board, so we believe you should be able to log into your Sierra Chart. What happens after you login? Are you unable to open a Chartbook? Are you not getting data? Are you getting an error when trying to connect to your trading service? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
