Date/Time: Fri, 04 Apr 2025 15:39:37 +0000
price chart offset from price scale
View Count: 313
[2023-01-05 13:59:17] |
rikki - Posts: 6 |
Hello SC support, i think that the image attached shows the issue better then a thousand words. Looking for a way to offset permanently the price chart so that i can read also the values given by the V profile moved on the right. I have done this manually so far but is very boring and unsustainable. Please help, Thanks |
[2023-01-05 14:11:26] |
User431178 - Posts: 634 |
Set space as required and enable 'Lock Fill Space'. Working With Charts: Right Side Fill Space |
[2023-01-05 14:15:24] |
rikki - Posts: 6 |
Thank you sooo much!!
