Date/Time: Sun, 22 Dec 2024 05:13:21 +0000
Hide Chart Drawings
View Count: 1087
[2014-06-02 16:18:11] |
Cigano - Posts: 2 |
Why is it necessary to include a Yes/No alert dialog when hiding chart drawings (>Menu >Chart >Hide Chart Drawings)? I am not deleting anything, just hiding drawings. This step seems redundant and cumbersome to me and probably also to anyone who uses this feature regularly. - Thanks
[2014-06-05 10:35:49] |
This will be reviewed.
[2014-06-05 18:29:26] |
JP - Posts: 24 |
Agree. its redundant. Perhaps having the option to disable it would be useful |
[2015-07-05 00:28:42] |
We could add an option for this but the primary reason for the prompt is that if someone accidentally selects this command and hides the chart drawings they are going to wonder what has happened. So from our perspective for support reasons the prompt is very important. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-07-05 04:00:38] |
Cigano - Posts: 2 |
Okay, it's not a serious annoyance, but as JP suggested - "Perhaps having the option to disable it would be useful".
