Date/Time: Fri, 04 Apr 2025 15:33:09 +0000
second free trial 13 years after first trial
View Count: 359
[2023-01-05 05:58:35] |
crahmed - Posts: 1 |
Dear Sir or Madam, Is it possible for me to have my software provisioned for another 15 day trial? I tried it out in May 2010 and have not used it since then. Interested in market profile.... Sincerely, Chris Ahmed |
[2023-01-05 06:45:08] |
Sierra_Chart Engineering - Posts: 19071 |
Your account has been activated and the usage time extended if necessary. If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu. After your Sierra Chart usage time ends you need to pay for additional usage time through "Help >> Add Usage Credit". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
