Date/Time: Fri, 04 Apr 2025 15:36:56 +0000
Share Drawings To Other Charts Idea
View Count: 314
[2023-01-04 23:51:15]
OrbitalD - Posts: 29
I'm looking for a way to hide chart drawing copied from select charts, rather than hiding drawings from all the charts at once.
As far as I know, you can share chart drawings from Chart1 -> Chart2 using Chart Settings, Chart Drawings, Copy Chart Drawings from Chart #'s.
And I can use Chart, Hide Chart Drawings From Other Charts (HCDFOC) to hide those copied drawings.
But if I have drawings from multiple charts copied, the HCDFOC option hides all the drawings from all the charts.
This works well but I would like to be able to hide drawings from a particular chart, not all the charts.
What if you enabled sharing chart drawings from Chart1 -> Chart2 -> Chart3? So that drawing on Chart1 are copied to Chart3 via Chart2.
This would mean that drawings on Chart1 would be copied to Chart2 and onto Chart3.
Then, if I used the HCDFOC on Chart2, this would hide only Chart1 drawings copied to Chart3.
Does that make sense? Using the middle, pass-though Chart2 as the switch to turn on/off Chart1 drawing copied to Chart3.
Thanks for you help, time, and attention!!!
