Date/Time: Wed, 09 Apr 2025 23:25:24 +0000
help with volume value lines not matching Volume profile stats
View Count: 362
[2023-01-04 17:53:28]
coachted - Posts: 389
I have a 30 min candle chart with a volume by profile study with time period for 'Fixed Time' set to Days and Time Period Length for Fixed Length set to 20 and a volume value area lines study with a Yes for Draw Developing Value Area Lines also set to 20 days...yet these two studies are providing 2 different VolPocs....I have attached the chart, can you please advise
attachmentChartbook4.Cht - Attached On 2023-01-04 17:53:10 UTC - Size: 7.44 KB - 292 views
[2023-01-05 16:22:33]
John - SC Support - Posts: 39249
Your Time Period Length on the Volume Value Area Lines is set to 20. You need to set this to 1.
[2023-01-06 17:49:20]
I am looking for the 20 day vpoc why would i use 1?
[2023-01-06 18:46:50]
Then you need to change your Volume By Price profile to be for 20 days, as right now it is only set for a single day.
In other words, you have a discrepancy between the two items, which is why you are seeing a different POC between the two. You need to get them matched up to get the same information.
