Date/Time: Wed, 27 Nov 2024 10:52:05 +0000
Equities Exchange Data connection
View Count: 440
[2023-01-04 17:50:26]
pampolpops - Posts: 12
I have a denali connection at ~$35/mo and want US equities live data but not order book data. It says I have to activate a real-time connection for $25 + $10 for US equities. Is it correct that my data fees would then be $70/mo for US equities + CME futures?
Specifically is there a way to add the live consolidated tape to Denali? I see here from Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* that "For the complete volume, the full consolidated tape data is required. This is offered through the Sierra Chart Real Time Exchange Data Feed and the US Equities exchange. The consolidated tape data feed for US equities will be offered through the Denali Exchange Data Feed sometime before the end of the year 2022."
[2023-01-05 16:11:18]
John - SC Support - Posts: 36309
Unfortunately we have not completed the work on the Consolidated Tape for the NASDAQ TotalView exchange that is part of the Denali Exchange Data Feed. Therefore, you do need to use the Sierra Chart exchange Data Feed for the U.S. Equities exchange that has the consolidated tape information. And yes, this means that your total data feed fees will be $69.75 per month.
[2023-01-10 07:32:54]
User410196 - Posts: 29
Is there any plan to complete consolidated tape for Nasdaq TV ? AFAIR it was planned to finish by end of December 2022
[2023-01-10 15:24:39]
Yes, it is still something we are working on. It is just taking longer than expected.
[2023-01-10 19:15:50]
Can you give some estimation about the timeline?
[2023-08-17 08:23:51]
Sierra_Chart Engineering - Posts: 17191
You can get the US equities consolidated tape through the Denali data feed now.
