Date/Time: Fri, 04 Apr 2025 15:36:56 +0000
studies
View Count: 297
[2023-01-04 17:35:54] |
Superbowl - Posts: 12 |
Hi I have 2 differents chartbooks and I d loke to export somme specific studies from graph 1 to graph 2. is there a simple way to do it ? garph 1 and graph 2 are registerred in the same chartbook |
[2023-01-04 20:49:09] |
Sierra_Chart Engineering - Posts: 19071 |
The way that you can move studies from one chart to another is through the use of Study Collections: Study Collections Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
