Date/Time: Fri, 04 Apr 2025 13:10:55 +0000
Data Is not updating
View Count: 286
[2023-01-04 17:15:47] |
User540796 - Posts: 3 |
12/30/22 16:59 is the last bit of data I have. New data is not being displayed. Please advise. |
[2023-01-04 18:01:10] |
Sierra_Chart Engineering - Posts: 19068 |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-01-04 18:01:18
