Date/Time: Fri, 04 Apr 2025 15:42:04 +0000
Issue with text in 2nd chart region
View Count: 331
[2023-01-04 17:14:52]
mbarbhaya - Posts: 37
Dear Support ,
I am not able to see the header text in 2nd chart region , I see the 1st and 3rd are good.
Please help me. Attached herewith is the captured image of the issue.
imageIssue with text in 2nd chart region.png / V - Attached On 2023-01-04 17:14:22 UTC - Size: 72.79 KB - 86 views
[2023-01-05 15:54:14]
John - SC Support - Posts: 39157
You need to look at the study that is in that region and check the settings on the Subgraph tab for Display Name and Value in Region Data Line (per Subgraph) and Display Study Name. If these are not enabled then nothing will show in the region header. Refer to the information starting at the following:
Chart Studies: Subgraphs Tab >> Display Name and Value in Region Data Line
