Date/Time: Fri, 11 Apr 2025 13:05:31 +0000
My Chart Setting Font is very Small
View Count: 358
[2023-01-04 16:56:36] |
User513390 - Posts: 49 |
Dear Friends, Wherever, i want to change a settings chart the font is very small as seen on the picture. Would you be able to help me to make it bigger. Thanks Rodney https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=74420 |
[2023-01-04 17:05:22] |
Sierra_Chart Engineering - Posts: 19129 |
Yes. You can adjust font sizes as documented here: Graphics Settings: Fonts and Text Appearance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-01-04 17:05:33
[2023-01-09 11:46:16] |
Very Thanks
