Date/Time: Fri, 04 Apr 2025 13:31:26 +0000
Sim Trading Issues
View Count: 318
[2023-01-04 14:21:07] |
Tin43 - Posts: 141 |
Hi, sorry to ask. I'm relatively new to this software. I want to sim trade the Dow. I set everything like it says on the Trading Sim section in the documentation. I set all for Trading Evaluator Delay. The problem is that I get a pop up message as you see in the image below. https://www.sierrachart.com/image.php?Image=1672841770300.png I see that the image above doesn't show the pop up message i get. I want to upload a screenshot, but doing with the sierra method doesn't shows the pop up in the chart. So I will put it here, it says "Service Client does not support market data subscriptions. Click for symbol information" I can't see price action due the price isn't moving. Apologies for my English. |
[2023-01-04 18:53:37] |
Sierra_Chart Engineering - Posts: 19068 |
For trading the Dow index you need to use Dow futures and the symbol is: YMH23 For more information about trading, refer to: Overview of Trading To open a chart, refer to: Getting Started, Opening Charts and Basic Trading: Open A Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-01-04 18:54:19
