Date/Time: Fri, 04 Apr 2025 13:31:26 +0000
Chartbook file is not compatible
View Count: 441
[2023-01-04 13:11:41] |
User609927 - Posts: 7 |
Hi, So I'm trying to open a chartbook file my Message Log is giving me this message: The Chartbook file is not compatible. Contact Sierra Chart support for help with converting it. File: C:\SierraChart\Data\CLT_Recording_.Cht | 2023-01-04 12:44:09.983 * How do I convert the file? I've attached the chartbook. Thanks Cody Date Time Of Last Edit: 2023-01-04 14:54:48
[2023-01-04 19:01:41] |
Sierra_Chart Engineering - Posts: 19068 |
This is something that you are able to update your self. Follow through the instructions here: Chartbooks (Workspaces): Opening Older Chartbooks Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
