Date/Time: Fri, 04 Apr 2025 13:03:34 +0000
Can I run 2 data feeds?
View Count: 610
[2023-01-04 12:43:07]
User551479 - Posts: 9
I have a question.
Can I open a separate instance and run a different data feed through it?
Or do I have to install a new SC occasion on my pc and then run the 2nd data feed that way?
(Can you run two data feeds at the same time by opening a new instance?)
[2023-01-04 19:04:42]
Sierra_Chart Engineering - Posts: 19068
Yes. Refer to:
Using Multiple Data and Trading Services at the Same Time
Not through File >> New Instance. You need to follow the instructions linked above.
Date Time Of Last Edit: 2023-01-04 19:04:54
