Date/Time: Fri, 04 Apr 2025 13:13:15 +0000
Binance Unavailable w/ CQG Service
View Count: 4368
[2023-01-04 10:12:53] |
Trader72391 - Posts: 3 |
My current service setting is set to CQG and I'm using Dentali data. When I switch the service setting to "SC Data" I see the Binance exchange available when I select a symbol. However, when I switch the service setting back to CQG this option disappears. Is it possible to get Binance data while the service setting is set to CQG (I understand I cannot execute but I still wish to monitor this market) ? Thanks. |
[2023-01-04 19:11:02] |
Sierra_Chart Engineering - Posts: 19068 |
If it is not listed it is not something that we are going to add. Install a separate copy of Sierra Chart: Using Multiple Data and Trading Services at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-01-04 19:11:11
