Date/Time: Fri, 18 Apr 2025 16:39:58 +0000
inquiring
View Count: 434
[2023-01-04 09:28:57] |
Rogers - Posts: 23 |
am inquiring if i can use my interactive broker account to set up with a live data feed
[2023-01-04 20:38:48] |
Sierra_Chart Engineering - Posts: 19269 |
Yes. Refer to: Interactive Brokers Trading Service When using Interactive Brokers we strongly recommend using the Denali Data Feed for exchanges that the Denali Data Feed provides data for: Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-01-04 20:54:52] |
kindly assist me with the set up of Denali data feed for exchange while to use the interactive broker has my funded account for not a professional trader
[2023-01-05 17:22:57] |
John - SC Support - Posts: 39356 |
The first thing you need to do in order to get data from our Denali Exchange Data Feed, as well as to connect to Interactive Brokers, is to be on one of the Integrated Packages. Since you are currently on the Base Advanced package, then you would most likely want to change to the Integrated Advanced. Here are the instructions to change your package: To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link.
Or go to this page: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation You will need to login if you are not currently logged in. In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button. The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price. There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted. When changing between Sierra Chart Service Packages, the usage time ending date on your Sierra Chart account is adjusted based upon the price differences between the package you are changing from and the package you are changing to. When changing to a higher priced package, your usage time ending date will be brought back closer in time. When changing to a lower-priced package, your usage time ending date will be brought forward further out in time. We are assuming you are wanting data from the CME Group, in which case follow the instructions at the following link: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-01-17 16:29:46] |
hello i have an account with iron beam broker kindly help on how to set up the live data feed for both CQG and denial data feed
[2023-01-17 17:00:58] |
If you are using IronBeam and trading the CME Group, then we recommend you look into the Teton Order Routing Service, as this could save you some money, as the Teton Order Routing Service does not have any fees (it could save you $0.10 per side on each trade). Refer to the following: Sierra Chart Teton Futures Order Routing But, if you are setup with CQG and want to stay with it, then follow the instructions at the following link to connect your Sierra Chart to your CQG account: CQG Trading Platform Service: Setup Instructions Then follow through the instructions at the following link to setup the CME Group data for the Denali Exchange Data Feed: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-01-18 08:15:54] |
am inquiring iron beam sent me this form so what data provider can i choose below as attached?
[2023-01-18 15:21:03] |
You will want to choose "Teton".
[2023-01-18 15:21:18] |
We recommend selecting Teton, as this is our Order Routing service, and, as you can see, it has no fees associated with it. If you are going to use the Teton Order Routing Service, then follow the instructions at the following link: Sierra Chart Teton Futures Order Routing: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
