Date/Time: Fri, 04 Apr 2025 13:33:46 +0000
[User Discussion] - Merging Same Internal Order Ids
View Count: 394
[2023-01-04 05:53:06] |
User410196 - Posts: 29 |
Hello, I am using SC with IB for equity trading and when I check Trade Activity Log's "Trade Activity" tab, I see there are partial orders listed there (same for "Trades" tab), what I would like to have all the same internal order ids squash into 1 order? Please see attached image. |
[2023-01-04 20:20:13] |
Sierra_Chart Engineering - Posts: 19068 |
This is definitely not possible to do. However, one thing you can do on the Trades tab is enable this setting: Trade Activity Log: Edit >> Flat to Flat Display for Trades List Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-01-04 20:20:28
